Revit 2020 - Wrong elevation tag orientation
Hi there,
Elevation tag shows as attached, but only on specific views. How do I change this?
- The project drawings have 2 perpendicular main plan view orientations for pratical purposes (site and floors views).
- No change when plan view's orientation is set to true or project north (to be noted: the option remains greyed out in the view properties winodw even when unchecked in the view template)
- Rotating the view frame solves the elevation tag issue, but then the drawing won't fit in the page. "Rotation on the page" not a solution, as the drawing title also rotates
- Body and pointer families not set to rotate with component (I tried changing those parameters with no success)
Any cue?
