Hi everyone,
Recently I had a problem with visibility in Revit. Everything all shows up in 3d views but when it comes to a floor plan, it shows blank at all. I have checked such related things to visibility(Phase, Phase filter, VV command, view range....) but it did not work. Can you guys have any solution for this?
Thank you so much.
Discipline ("Coordination" or "Structural"..)?
Filters?
do you have any Links loaded into the project. Links could make some elements not visible sometimes
I attached the link so that you can check with your current situation. I hope it helps you.
yes, even in Coordination and Structural as well. Showing up in 3D is ok.
I even tried in Zoom to fit option but it doesn't work at all.
I have found your solution before uploading this post. Does not work 😞
The reasons that things don't show up are numerous. Share your file for a direct responce instead of guesses.
