Views inside views on Project Browser which are Independent
info
info
I have a revit file from a client which has Views inside views on Project Browser which are Independent!
Top Level is Browser Organiser - Can be created that through adding a
Parameter to a  View Template -
But I don't know how they have create the following tree- Having two levels of views where the lowest is Independent.
Looks to me like they added a Project Parameter to Views, and are sorting the Project Brower using this Project Parameter's values. Be pretty easy to confirm though.  Right-click on Views=>Project Organization to see what it is.
TripleM-Dev.net
As @barthbradley mentioned the top level name is a project defined parameter attached to the Views category.
The second is the View's Family/type name.
