Can't see dimensions exported Autocad file.
info
info
Can't see any dimensions in exported Autocad file.
I need to determine an angle of a roof pitch but I can't dimension it. No dimensions work. I've checked layer setting & created a new dim style.
I had to copy the roof over to another cad file to get the dimension!!!!!!!
info
I solved it!
The view I exported from Revit was 3D, and it created an 3D autocad file. But the view was a face-on elevation.
I only have Autocad Lt.
So I'm guessing I can't dimension 3D geometry in 2D. The dimension could be going off into infinity.
ennujozlagam
post some screenshot for better understanding on what are your trying to achieve? thanks
