View templates not transferring through "transfer project standards"
3 REPLIES 3
822 Views, 3 Replies
We seem to be having trouble transferring project standars (specifically view templates) from one project to another. We have tried everything we've found in forums and nothing has worked, we have even tried moving everything into a brand new file and then transferring the project standards, but still haven't succeded. We are working in Revit 2016 and have succesfully transferred everything except view templates and the project browser organization.
It is absolutely necessary for us to solve this problem to continue working in the project since we're doing five construction manuals for five different houses, each has its own project file but all of them need to have the same views and format.
If anyone has had a similar problem and got a solution, please give us a hand.
3 REPLIES 3
diegoaev
clean up all geometry, floor plans section plans, sheets, all the rest. purge it all BUT the view templates. save as compact file, erase all links and imported private property cad work and send me the file. I will try in on my pc
MichaelBussiere2
Thank you for your post.  It looks like you are having difficulty transferring project standards from one model to another in your Revit 2016 software.
In this case, there may be a communication issue in the file itself.  If possible, please attach a copy of the model in question and I would be happy to test this further.  Thank you and we look forward to your reply to best help in this case moving forward.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
MichaelBussiere2
We wanted to check back in with you on this post.  How is everything working out?  Please let us know if further assistance is needed from the community on this post.  We are happy to help wherever possible.  Thank you and we look forward to your reply update.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Forma Design Contest
Technology Administrators
