Selecting two materials to put on different faces of a modelled-in-place pyramid
6 REPLIES 6
cct31d16
1193 Views, 6 Replies
I modelled-in-place a pyramid as a generic object using a blend. Next I created a passageway through the tunnel using two void extrusions. I figured out how to apply a stone material to the whole pyramid by adding a material parameter. I want to apply a second material to the inside passageway faces formed by the void extrusions. I added a second material parameter to the properties, and I know how to tab to select the faces I want to "paint" the second material, but the Paint tool doesn't read the object when I try to use it, and when I pick the extrusions with "edit extrusions" there is no way to access materials. I'd appreciate any guidance on how to add a second material to certain selected faces.
6 REPLIES 6
L.Maas
in reply to: cct31d16
When you have an in-place component you have to go to edit mode to be able to paint the different faces
Louis
Please mention Revit version, especially when uploading Revit files.
cct31d16
in reply to: L.Maas
Thank you for replying. I have tried to edit in place. I only can access the edit in place icon when in a 2D view. I select the void extrusion to edit, select the paint tool and select material I want, click finish model. Nothing changes.  I'm clearly missing something! When in edit in place I've also tried to edit the profile of the extrusion, but it doesn't have the paint tool, just seems to be for changing the size.
L.Maas
Ok, you can't paint the void itself. A void is 'nothing' so can not be painted. You have to edit and paint the pyramid. The faces that were generated because of the void cut outs should be painted.
Otherwise upload the relevant parts of your model and we can have a look.
Louis
RDAOU
@cct31d16
It works as follows...see screencast. If it is still not working out ... then upload/attach the Revit file so one could guide you accordinagly
cct31d16
in reply to: L.Maas
that makes sense! I tried again in the family file and this time got the paint tool/selecting faces sequence down right. I want to model the faces more, but am happy to get the materials on. Thank you- it was my first time using the forum and you helped get me to keep at it.
cct31d16
in reply to: RDAOU
thanks-I finally got the paint tool/selecting faces while editing in place sequence right. you can see jpeg from my other reply.
