View Range Problem
View Range Problem
victorveo
View Range Problem
victorveo
Hello, im new at revit and i have a little problem.
I have a concrete structure with metal beams above, I am trying to generate a floor plan where you can see the metal beams.
I try to generate the plane with the view range associated with level 4 and the metal beams are not visible, should not these be seen if the top view plane is above the metal beams? And I do not understand why if the lower plane is at -0.5 and the view depth is at -0.6, the lower slab is visible
Sorry about my english, thank you
How about a reflected ceiling plan or a structural plan view looking up?
victorveo
thanks for the reply, It's probably a solution, but what I'm looking for is trying to understand why it does not work this way
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Do you have any floor above the beam that cover it from view? Try change the view to wireframe and detail level to Fine see if you can see the beam.
