I created a custom baluster that I want to use for my railing, I'm however having issues trying to get the baluster to be at the center of the rail, a bit difficult to explain so I've attached some images. its almost as if its been offset to the outside of the rail but i don't know how, I just need it to be at the center and line with the rail.
erm.. not sure, I got rid of all the rails so I think its a non continuous
I've done it, you were right the rail was a top rail, I had to change the offset of the hand clearance to half the thickness of the rail, so the rail was 60mm thick and I changed the handrail clearance to -30mm to get the baluster to be at the center. Thanks for you help!
