View Range option locked in
antonio_roquette
antonio_roquette
My bottom option on the view range menu is "linked" to the cut plane option, so its value just copies it, and I am unable to change it. Any way I can solve that?
jay_colcombe
This is because it is a Reflected Ceiling Plan so works differently to a Floor Plan View Range
Jay Colcombe
Autodesk Certified Instructor
ralphdenhaan
This is how structural floor plans and reflected ceiling plans work.
The bottom is shared with the cut plane. view-range-revit/
However, you can modify the View Direction to Down for structural floor plans making it possible to change the bottom plane again.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
jay_colcombe
From the Values in the image i would have suggested it was a ceiling plan?  Glad its sorted!
Jay Colcombe
