Filtres Transperancy
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
emergesecondary09
318 Aufrufe, 6 Antworten
I am not able to redue the tranperacny of the filer that i have applied for my floor. Is there a way to solve this ? I tried reducing the transperacny but its not working.
20% Transperacny and the image has the pdf of the view
50% Transperacny
even though the transperacny is reduce the hatch patter looks same in the pdf. I want the transperacny of the pattern to be dull without using the half tone
6 ANTWORTEN 6
Nachricht 2 von 7
jay_colcombe
als Antwort auf: emergesecondary09
I do not think Transparency Works Well with Hatch Patterns but more Solid or Material Fills and it was always recommended to use Halftone.
You could always use a Color with a reduced Lum: Value
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 7
I am ok with using the halftone but it tones down the lines too, is there a way to keep the line normal ?
Nachricht 4 von 7
jay_colcombe
Apart from right clicking and using Override Graphics in View, but defeats the Filter functionality a little!
Jay Colcombe
Nachricht 5 von 7
How can you tell? Is there anything beneath the floor to see?  If not, what's the purpose of making the floor transparent?
Nachricht 6 von 7
...maybe you just need to lower your Bottom and Depth View Range settings.
Nachricht 7 von 7
Transparency and halftone are entirely different things.  I have never seen anyone suggesting using halftone to make things appear transparent, so I do not understand why @jay_colcombe suggests "halftone is always recommended".
