View and Modification options on different levels
Message 1 of 9
Good day
I'm busy with a tutorial house plan (Training). Level 1 + Level 2 + Roof...
Adding windows and doors on level 1 was fine. (It gave me modification options to flip doors see to which side it opens...).
Now I started with level 2 and it wont show me where I placed a window or door or which side it opens to or select it... When I move to 3D view it shows but not in 2D Level 2.
Not sure if it might just be a setting...?
Level 1
Regards
Natasha
Replies (8)
Message 2 of 9
Ilic.Andrej
Maybe the problem is about the view range. Open the floor plan, find "View Range" in the properties palette. See where the cut plane is.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 9
ennujozlagam
check your view range setting in properties, adjust your value . thanks
Message 4 of 9
Thank you
There is defiantly an improvement but now the doors are gone in 2D view.
Message 5 of 9
Ilic.Andrej
Change level of detail from coarse to fine. Maybe that's the issue
Andrej Ilić
MSc Arch
Message 6 of 9
Hi
Thank, but I did try that. I also noticed that trying to place a door creates the issue if not showing the door in the location I want to place it. It does however show me the dimensions but not the door.
I received this warning issue... Help please.
Message 7 of 9
Would like to thank all for your help!! I managed to fix the issue!!!
Solution: To resolve the issue, try the following:
  1. Check visibility of elements in the view. Click View tab Graphics panel (Visibility/Graphics). ...
  2. Check design option settings for the view. Click View tab Graphics panel (Visibility/Graphics).
Feb 11, 2019
Message 8 of 9
Here's 33 more for you if you encounter that warning again...
https://www.revitforum.org/tutorials-tips-tricks/441-cant-see-view-heres-33-reasons-maybe-why.html
Message 9 of 9
Thanks sooooo Much. This is great! Appreciate all the help!!!
