Curtain wall system grids
2 ANTWORTEN 2
Nachricht 1 von 3
258 Aufrufe, 2 Antworten
I know this gets talked about a fair bit, but I can't figure out a workaround.
I'm trying to create a curved/sloped curtain wall spanning over many floors which is only one panel wide. At the moment it appears the panel family is rotated 90deg within their locations. I think this is to do with the u/v direction of the slope. I have tried creating it as a mass using an extrusion and also as a sweep to see if the direction of creation would help. I've also tried to subdivide a surface and rotate the grids in that, but again no joy. If anyone has any ideas I'd really appreciate it.
2 ANTWORTEN 2
Nachricht 2 von 3
borakin1
als Antwort auf: Anonymous
Hi;
Maybe you can rotate your panel family? Or you can change curtain wall propeties to horizontal and vertical dimension fixed type ?
Bora AKIN
Mimar
Twitter | LinkedIn
Verilen cevap sizin için çözüm mü? Eğer çözüm ise  ÇÖZÜMÜ KABUL ET  veya BEĞEN Kudos.jpg butonu ile ödüllendire bilirsiniz.
Nachricht 3 von 3
als Antwort auf: borakin1
Hi Borakin, I'm reluctant to rotate the elements within the family.
@borakin1 wrote:
...Or you can change curtain wall propeties to horizontal and vertical dimension fixed type ?
I'm not sure what this means... Could you please explain?
