Varying Door Panel Lengths
5 REPLIES 5
ronil.jain
554 Views, 5 Replies
I wish to change the oanel lengths in the generic door family so as to have one panel which is smaller than the other rather than both panels having equal lengths.
Tags (3)
Labels (1)
5 REPLIES 5
in reply to: ronil.jain
Revit has one in the OOTB Content Library. Door-Passage-Uneven-Flush.rfa. Under Doors\Commercial.
ronil.jain
in reply to: barthbradley
Is it possible for you to share the said family, asm y library is pretty messed up will trying looking for it on the net as well. Also tysm
ronil.jain
Also how can I change the settings of a family so that when i add them to a file their visibility behaves of the various components behaves a certain way.
Mike.FORM
To change how parts of the family are displayed in various views you can open up the family editor, select an element(door, frame, trim, etc...) then open the visibility settings for that element
Forma Design Contest
Technology Administrators
