Variable slab thickness
Message 1 of 9
what would be the easiest way to create RC slab with variable thickness? 19cm at the begining and 17cm at its end in my case.
Regards!
Replies (8)
Message 2 of 9
MostafaElashmawy
The easiest way is to model in place sweep or blend.
another easy way is to make ordinary slab then use edit shape tool to raise it at one edge.(before you do that you mast make sure that the layer of the material is variable)
Please check attached photos.
Mostafa Elashmawy
Message 3 of 9
Ilic.Andrej
Create structural or architectural floor:
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 4 of 9
Excellent!
One more thing! How can I hide diagonal lines created after editing slab thickness!? I'm only supposed to make rebar drawings so fabrics annotations won't be clear!
Regards!
Message 5 of 9
MostafaElashmawy
Visibility grapgics overrides>> click the  + beside floor >> uncheck interior lines.
Mostafa Elashmawy
Message 6 of 9
Ilic.Andrej
Those lines appear depending on how the floor is sloping.
Andrej Ilić
MSc Arch
Message 7 of 9
Thank you once again!
I just unchecked "Visibility/Graphics -> Floors -> Interior Edges".....
Message 8 of 9
rdean278
When I select "Edit Assembly" the "variable" box does not appear.  How do I get that option?
Message 9 of 9
rdean278
The slabs have the "variable" option in architectural revit but not in structural revit
