Wrapping of Compound Wall
saad.fakhoury
Message 1 of 9
saad.fakhoury
Hi all,
I am facing some troubles in wrapping the compound walls.
Firstly, here are the components of the compound wall:
The Wrapping of this wall works OK when the walls' components are coming out from the same level:
BUT, the Wrapping of this wall DOESN'T works OK when the walls' components are coming out from DIFFERENT levels:
And I need to draw the compound wall coming out from different levels.
HOW CAN I DO THAT?
Help me, please.
Replies (8)
Message 2 of 9
MostafaElashmawy
may be the join is disallowed.
Please check below link to join walls.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Mostafa Elashmawy
Message 3 of 9
saad.fakhoury
Dear Moustafa,
Thanks for your reply.
I've tried it now but it doesn't work.
Message 4 of 9
MostafaElashmawy
Would you please share a 3d shot of tge intersection between tge two walls.
Mostafa Elashmawy
Message 5 of 9
saad.fakhoury
Sorry, the request was posted twice by mistake!
Here is your request:
Message 6 of 9
MostafaElashmawy
Sometimes this would happen if you use the tool align to align ends of walls.
Try using Trim/Extend tools.
these tools should force the wall corners to behave correctly.
Mostafa Elashmawy
Message 7 of 9
saad.fakhoury
SORRY FOR BEING LATE in my reply,
According to your last saying, IT WAS NOT solved.
BUT
I have copied the wall to another file in order to give it to you here but the wrapping was solved in the NEW file!
I copied it again from the new file to my Ordinary project I am working it the wrapping went wrong again !!!
So it seems it is a MISTAKE in the settings of the file !!!
Message 8 of 9
Do you have a wall in a different phase (existing wall being demolished for example) or a room separation line at the very corner?  Turn the Phase filter to Show All to inspect.
Message 9 of 9
saad.fakhoury
No the same phase, and no room separation.
This photo shows what I am suffering from:
The photo at the right presents the wrapping error in the walls,
when I have copied the walls and past them in a new file, the wrapping of walls was OK and this is shown in the photo at left.
My question now; what is the trouble in my project that prevents the walls from wrapping in a correct way?
