Is it possible to hide callout boundary and just keep callout bubble?
Any suggestion would be appreciated.
Gelöst! Gehe zur Lösung
Gelöst von MostafaElashmawy. Gehe zur Lösung
one solution is :
After you draw the callout, hide it in view then you can use the view reference tool to refer to the desired view.
view reference family can be updated to match the callout head family.
Mostafa Elashmawy
also you can turn the colors of the call-out boundary line into white at Object styles
Mostafa Elashmawy
Thank you for kindly reply.
But I am not so sure what you mean about "hide it in view".
Does it mean hiding entire callout or hiding the callout bubble?
