Using the inches symbol " in Keynotes
craig
Message 1 of 9
craig
I have been using the inches symbol (") in Keynote for many years. I just created a new Keynote entry in Revit 2022 that uses an inch symbol, but when that family is tagged instead of displaying the inch symbol it displays (a€).  I thought that there was a way around this using double quotes, but it's simply displays multiple a€. Any ideas?
Replies (8)
Message 2 of 9
SteveKStafford
You can use a pair of single quotes to look like double and that will "work", fool Revit and the keynote file.
Steve Stafford
Message 3 of 9
craig
Thanks Steve. Apparently revit will no longer be fooled. That produced the same results. Older inch symbols that are in the file still work, so I copied one of those to this new note and it works! Go figure.
Message 4 of 9
SteveKStafford
Hmm, I just did it in 2024 before replying, used the single quotes and it worked fine. Are you using Keynote Manager by any chance? If so maybe there is something going on between Revit and the app?
Steve Stafford
Message 5 of 9
craig
I appreciate that Steve. Thank you. My workflow is perhaps more complicated than Keynote manager. I'm running Revit on a Windows virtual machine using Parallels on a Mac Studio M2. My Keynote file is a Numbers document from which I export to a Tab Separated Value file. Then I modify the .TSV extension to .TXT and reference it as my Keynote file in Revit. This all worked like a charm with my old iMac. Perhaps there is different programing going on under the hood in this new computer and OS to produce what looks like an inch symbol!?
Message 6 of 9
SteveKStafford
Aah, that is more involved. I'd bet the conversion process is introducing a different font code for double quotes. I know I've had to be careful to specify the correct ANSI values using Excel exports when going from CSV to TXT.
At least copying an existing symbol worked, for now 😉 Good luck!
Steve Stafford
Message 7 of 9
How do you edit Keynote file? Excel?
Message 8 of 9
craig
Message 9 of 9
HVAC-Novice
I don't know anything about Mac... but i use Google sheets to edit the notes (since that also allows me to share the file with other team members and have them edit it). Then download to the txt file format. Maybe try the same.
My head spins reading your long process to do that... but I bet somewhere in that process is where the " causes issue, not in Revit. Also look into the txt file after your process, if that has the ".
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
