Use same edited crop region in multiple views
HVAC-Novice
Advisor Advisor
HVAC-Novice
Scope boxes only seem to work for rectangular crop region. I need a solution for irregular (edited) crop region.
I have the need to crop views of complex work areas. I need the very same crop region for the demo view, and for all discipline views etc. How do I do that?
I tried to copy/paste a crop region, which didn't work as expected.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Edit the crop, copyclip the sketch lines, edit other views crop sketch and paste aligned.
HVAC-Novice
Thanks. That works. I also learned it is easier to delete the second (edited) lines first before pasting the first set of lines. I originally left that set of lines before pasting. and since i had that edited and it looked similar to the other set of lines, it was hard to see which one to delete. So, delete first before pasting.
I'll mark yours a solution since at this point this seems to be all that Revit offers. but if anyone has more ideas, please share.
There is an idea to vote on for editable scope box
