Quick way to disable volume calculations - a toggle, quick access toolbar or similar
2 ANTWORTEN 2
Nachricht 1 von 3
HVAC-Novice
199 Aufrufe, 2 Antworten
Is there a way create a quick access or toggle button to change the volume calculation on the fly without having to go into the settings?
I usually have volume calculations enabled since a lot of my design depends on that. But on a larger project it takes some seconds to re-calculate large room volumes when changing a rooms separator or similar. I noticed disabling volume calculations helps quite a bit. I'd like to be able to quickly disable volume Cal cautions if I do things not requiring volume calculations.
I didn't see a way to add this to the quick access toolbar.
(I know, a decent computer would help.....)
Revit version: R2025.4
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: HVAC-Novice
You can create a keyboard shortcut to the dialog but you still need to change it yourself.
Nachricht 3 von 3
HVAC-Novice
als Antwort auf: ToanDN
Thanks. that may be the best crutch to do this.
In an ideal world it would be a toggle that changes color based on status.
