Hey Revit Gurus,
I've been playing with Project Parameters and Tags with some new success and of course some hangups.
Specifically I am adding some information to individual wall elements via Project Parameters, then using Wall Tags to display information annotatively.
I was able to get Text and Number Shared Parameters applied to wall elements (Project Parameters), and then I was able to taq these values via Labels inside of a Tag Family.
Now I want to take a simple Yes/No shared parameter applied to the walls (Project Parameters), and use that as a visibility parameter in the tag.
Is there a way to Refer to the Shared Project Parameter of the tagged element as a parameter in the Tag Family?
I tried setting the Visibility parameter of the text string "FTAO" to the 'FTAO' shared parameter. But it seems like I need to get the shared parameter directly into TAG family. Perhaps there is a way to set a visibility parameter in the family and then set it equal to the shared project parameter but I cant figure out how that would look.
You can see that I was able to add and tag two other Shared Project Parameters from the wall into the tag label directly, so I feel that I should be able to get the Yes/No parameter information into the tag too its just not working intuitively.
