Use Project Parameter (Yes/No) to control visibility within Tag.
paul
paul
Hey Revit Gurus,
I've been playing with Project Parameters and Tags with some new success and of course some hangups.
Specifically I am adding some information to individual wall elements via Project Parameters, then using Wall Tags to display information annotatively.
I was able to get Text and Number Shared Parameters applied to wall elements (Project Parameters), and then I was able to taq these values via Labels inside of a Tag Family.
Now I want to take a simple Yes/No shared parameter applied to the walls (Project Parameters), and use that as a visibility parameter in the tag.
Is there a way to Refer to the Shared Project Parameter of the tagged element as a parameter in the Tag Family?
I tried setting the Visibility parameter of the text string "FTAO" to the 'FTAO' shared parameter. But it seems like I need to get the shared parameter directly into TAG family. Perhaps there is a way to set a visibility parameter in the family and then set it equal to the shared project parameter but I cant figure out how that would look.
You can see that I was able to add and tag two other Shared Project Parameters from the wall into the tag label directly, so I feel that I should be able to get the Yes/No parameter information into the tag too its just not working intuitively.
- Do not add FTAO shared parameter to your tag family via Family parameters.  If you already did, delete it.
- Create a label in the tag family, add FTAO shared parameter to the list on the left
- Add a calculated value parameter to the label, use this formula: if (FTAO, "FTAO", "")
paul
How did I know @ToanDN would help me out here ?
Thanks this works excellently.
mhiserZFHXS
So you just want the FTAO to toggle on and off with the checkbox?
I think the best solution will be to add an additional text parameter to the walls, set its equation to:
if(FTAO, "FTAO", " ")- Quotation marks required, and space between the second set.
Then use that parameter to control an additional label in the tag.
paul
I didn't know you could add computed parameters like that to a system family.  How would you start that process just curious? @ToanDN had a solution that works exactly as I need.
mhiserZFHXS
You're right. My bad. Was completely negating the system family issue!
