Units in revit
Units in revit
Message 1 of 8
Units in revit
hi dear users
i  want to just Metric templates have in my revit how i can disable  imperial unit templates ?
Replies (7)
Message 2 of 8
Ilic.Andrej
Templates are stored here:
ProgramData/Autodesk/RVT 2016 (...or 2017, 2018....) /Templates
When you re creating a new project, click on the button "browse" and navigate to DefaultMetric Template.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 8
Are you talking about completely removing the Imperial Templates, or editing the Project Templates list?
For removing the templates completely, you can go to C:\ProgramData\Autodesk\RVT 2018\Templates, select the US Imperial Folder and delete. There might be an easier way but that will work
Here's a useful link for defining your Project Template List
Message 4 of 8
 thanks
 but i want to my revit program default unit  be in metric nor imperial > how can i  do that ?
Message 5 of 8
it have not affect on the program ?
it still works
are you sure ?!
Message 6 of 8
Here's how to add the Metric Templates to the List. All you need to do is select the US Imperial templates you wish to remove and click the "-" button
  1. Create the project templates that you want to include in the list.
  2. Click Options.
  3. Click the File Locations tab.
  4. Add one or more templates to the Project template files list, as follows:
    1. Click  (Add Value).
    2. Under Name, replace the default template name with a meaningful name.
    3. Click in the Path column, and click .
    4. Navigate to the project template file, select it, and click Open.
      The template is added to the list.
Message 7 of 8
Ilic.Andrej
The template drives anything that is "default". Start new project using metric template and then use "un" shortcut. You will see that units are metric.
Andrej Ilić
MSc Arch
Message 8 of 8
thank you
