Units confusion
Units confusion
juancano_arq
Message 1 of 11
Units confusion
juancano_arq
I have a little confusion about units, it'd be kinda dumb question but I gotta try.
If I'm working a project in Meters, and if 0.1m it's 10 cm, 0.01m it's 1 cm and 0.001 it's 1 mm, what's 0.0001m?
Thanks for answer!
Replies (10)
Message 2 of 11
curtisridenour
0.1 mm?
Message 3 of 11
juancano_arq
Hi @curtisridenour , how are you?
Yes, I know. I guess I wasn't clear with my question. I want to know what metric unit it's that. We got Meters, Centimeters, Milimeters... but what metric unit is 0.0001 m?
Message 4 of 11
mhiserZFHXS
Why not just look it up on a search engine? This is kind of an odd question to ask here. Someone might know but it'd take two seconds to just look it up yourself.
Message 5 of 11
juancano_arq
@mhiserZFHXS why not just ignore this question and mind your own business if you don't have the answer? 😉
Message 6 of 11
curtisridenour
@mhiserZFHXS is correct and he was courteous in his response. No need to be rude.
Message 7 of 11
HVAC-Novice
https://chem.beloit.edu/edetc/nanoscale/index.html
There are also online converters
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 8 of 11
juancano_arq
Hi, if I'm making the question here is because I can't find it in Google. My question is not about converting something, is about this:
If I'm working my project in Revit, in Metric Units, and you call 0.10 m = 10 CENTIMETERS, 0.001 m = 1 MILLIMETER, how do you call 0.0001 m?
Sorry if I looked rude, wasn't my intention.
@HVAC-Novice @curtisridenour @mhiserZFHXS
Message 9 of 11
SteveKStafford
From the Jedi Archives (Google)
Micrometer A micrometer (also called a micron) is 1000 times smaller than a millimeter.
1 millimeter (mm) = 1000 micrometers (μm).
A nanometer is 1000 times smaller than a micrometer.
I'll add...Revit won't let you draw something 0.0001 meters long anyway...
Steve Stafford
Message 10 of 11
Mike.FORM
Here is a chart listing the naming for metric systems.
0.0001m would be equal to 100 micrometers. There is no deci- or centi- equivalent.
Message 11 of 11
It's still a metric unit. Like a tenth of an inch is still an imperial unit.
