Would like to share this with Revit Developer. Hoping to have an option to tag the "UNITS" in the overall plan by not using the room tags. Let's say, have 10 units in one level plan. Unit A1, A2......A10, currently Revit won't allow us to tag this unit in general tagging. The only option is to name the Units in textnote which is not ideal. Another option currently available is to disable the room bounding of the walls to tag as one whole unit using room tag which is not a good option also since we would like to maintain the individual room tags in enlarged plans of each units.
Hopefully, the next version will give us an option to tag the units and maintain the room bounding of walls. and at the same times unit tag can calculate the perimeter area of the Unit.
Thank you.
Best Regars,
Jeg
Thank you.
Best Regars,
Jeg
Solved by jEg2x-2023. Go to Solution.
Solved by RDAOU. Go to Solution.
You can either combine Rooms and Areas or simply use Spaces and Zone...You can tag a Zone which includes more than one space
If you insist on having the same feature for rooms...you can try your luck and post it on the Ideas forum (Follow the Link Below)
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Hello RDAOU,
Thank you so much for the suggestion. will try to put this into revit ideas.
I have received also a suggestion from this guys,:
https://forums.autodesk.com/t5/revit-architecture-forum/unit/td-p/11007974#M350051
you might like the idea on how to set up unit tagging.
Thank you.
Hello RDAOU,
Thank you.
I'm good with Zones and Spaces... replicating the same function is more or less redundant
Do you have a video link maybe from youtube or different video site that shows on how to to it ? Tried the space and zoning option but still it limits me to room bounding inside Unit.
You place Spaces
You Add Spaces to a Zone
You place Spaces
Thank you so much for this. I feel like this is more effective way of showing the unit tag in an overall plan.
Do you have any idea on how to combine the gross and net area in one schedule? or maybe try to link them so we can add a formula between them?
Thank you.
Best regards,
Jeg
Thank you.
Best regards,
Jeg
I am afraid I do not understand the question...is this still about tagging or are you talking about area schedules and area plans?
If the latte then please start a new thread/post
Sorry, to jump into a different topic. I was referring to area schedules, rentable and gross. Wondering if you know on how to combine them in one schedule table. Or maybe link them.
Thank you.
Thank you.
The short answer is no; not in a straight forward way no there isn't.
There are several workarounds though...Do you have a schedule format in mind?
I am trying to formulate heated area(rentable) unheated area, and total area(gross area)
Well first you need to use the same Area Type schedule ...
With check/uncheck Itemize every Instance it looks like below...You can also transpose it so all stand in the same row
