Unit format - base point Proyect
freeriderfx
Message 1 of 12
freeriderfx
Why my base project unit are in Meters and not in gg°mm′ss″ (Sexagesimal System)
I want to put the real location of the project.
Any idea?
Replies (11)
Message 2 of 12
That doesn't make any sense.  Can you explain how would that work?
Message 3 of 12
freeriderfx
Since when Lat/long are in Meters?
Message 4 of 12
So my example of the Sexagesimal System has disappeared for no reasons?
Message 5 of 12
You are looking at the wrong thing.
Message 6 of 12
They are not.
I think you are confused.  Those a Cartesian Coordinates
...@freeriderfx, check this out:
https://revitpure.com/blog/13-tips-to-understand-revit-base-points-and-coordinate-system
Message 7 of 12
freeriderfx
UTM.pngAlready Solved it, this will make it (UTM coordinates)
Message 8 of 12
So you moved the Survey Point.
Message 9 of 12
freeriderfx
UTM.pngI accquired coordinates from the CAD file and modified the family to get the "UTM coorinates"
Message 10 of 12
Yes, by Acquiring Coordinates you moved the Survey Point.  I don't understand what you mean by you "modified the family to get the 'UTM coordinates'".  Can you elaborate?
Message 11 of 12
freeriderfx
Intead of having "m" (meters) in the field I just added X,Y intead and "Elev" for elevationIntead of having "m" (meters) in the field I just added X,Y intead and "Elev" for elevation
Message 12 of 12
Okay, so it doesn't say meters, but it is meters.
Something you ought to be aware of: Revit has a 10 mile maximum radius distance limit.  Read list AKN article:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2019/...
