Underlays
3 REPLIES 3
jfjacques
202 Views, 3 Replies
Underlays
Any way of getting options in underlays? Also not able to get different views. Are they just limited to levels?
3 REPLIES 3
in reply to: jfjacques
No options other than View Range and Direction.  You cannot choose what view for Underlay, only Level.  But if you place several  views on top of each others on a Sheet.
Underlay is used for only levels and it's setting is from the Properties of the level view.
You can also manage the graphic of your underlay from the manage tab,Additional Setting, Halftone/Underlay.
 I just attached the photo for you.
Forma Design Contest
