Windows 10 Creators Update
3 ANTWORTEN 3
Nachricht 1 von 4
1435 Aufrufe, 3 Antworten
Is anybody running R17 on the Windows 10 Creators Update that is going to be released soon? Are there any issues or will Revit 17 run under the new OS upgrade?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
“As Windows 10 Creators Update nears completion, new build focuses on fixes
Lots is fixed, but some strange glitches persist.”
Doesn't sound all that encouraging. I'd be extremely reticent about using it on my Revit workstations.
Nachricht 3 von 4
als Antwort auf: barthbradley
This article gives options of delaying the install.
https://www.thurrott.com/windows/windows-10/106922/windows-10-tip-get-creators-update-schedule
May be worth a breathing space for a few weeks until more is known.
Good luck.
Nachricht 4 von 4
aksting
Although I don't use Revit, I have had problems with Vault after the creators update. I couldn't figure out what the problem was so I reverted back to before the update. So if you use decide to try the upgrade always  do a back up of everything before attempting the upgrade.
