Underlay set to none
m.voss.alvine
Message 1 of 13
m.voss.alvine
When a new floor plan is created, Revit automatically sets the underlay to the floor below.  90% of views never need an underlay.  Underlay should be set to none by default.
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
Replies (12)
Message 2 of 13
doni49
I'm using Revit 2016 here.  It doesn't do that for me -- I just made a new floor plan view.  UNDERLAY is set to NONE without me doing anything.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 3 of 13
m.voss.alvine
you have to have a project with multiple levels for it to happen.  Copy your level up and create a floor plan for your new level.
Message 4 of 13
doni49
My project has THREE levels.  The one I used to create the new view was the middle one (so there was one above and one below).
Don Ireland
Message 5 of 13
doni49
Don Ireland
Message 6 of 13
m.voss.alvine
this is what we get
Message 7 of 13
doni49
I'm thinking that there must be a setting somewhere that does this. I've never had underlays show up automatically.
Someone should chime in with more info.
Don Ireland
Message 8 of 13
@m.voss.alvine The OOTB Arch Template does do this when you get to the second floor.
Really, the only way to fix it is to create your own template with multiple levels pre-made (we have 12, with all sheets created for those 12) and all of them with the underlay turned off.
Message 9 of 13
Just tested it with the 2017 OOTB template and all New floor plans created with None underlay.
Message 10 of 13
Level 2 was set to underlay Level 1....but yes, all New views were set to none on my machine too.
Message 11 of 13
doni49
MP:
That explains it. Our templates have three levels created already and modify them as needed.
Don Ireland
Message 12 of 13
m.voss.alvine
i have not had to set up a project in 2017 yet, only upgrade existing projects.  Glad it only took a couple of years to fix.
Message 13 of 13
chrisplyler
I'm just guessing here because I'm not going to set up a test project to try it out in, but...
...Is it possible that if you copy up a Level who's associated plan view has no underlay that the new Level plan would also have no underlay, and that if you copy up a Level who's associated plan view does have an underlay that the new Level plan would also have an underlay?
