Toposurface - Section View
hi all.
I have managed to create Toposurface for a project site.  In 3D it looks good and I can see the gradient and changes in slope.
I have created a section across the area with the most gradient difference, but in Section view all I see is a flat Topography.
What settings do I need to adjust to see the gradient differences? I know they are there, but right now it looks like completely flat surface.
Thanks again in advance.
Helen
Alfredo_Medina
@Anonymous Can you post some images? (the 3d view and the section view).
Thanks Alfredo - I don't have the file with me right now but I will.
I am wondering is it to do with the scale of the Vertical Axis.  Is there a way to check /set the lowest point of the elevation so that I am seeing the topography elevation changes in more of an exaggerated way?    I am wondering now if I have somehow set the lowest point at zero elevation (though I didn't set any point at o) and therefore, if most of my points are above 50,000mm mark then I wont see the change.  Sorry if I am unclear I  will post my visuals when I get the file again.
