unable to unhide baseboard
mwang7DKXEF
Message 1 of 14
mwang7DKXEF
I hide the baseboard from elevation view, later it is unable to unhide.
Thank you
Accepted solutions (3)
Replies (13)
Message 2 of 14
Edit: VG and Unhide Wall Sweep subcategory.  If that doesn't work then check Filters.
Click Light bulb button to Reveal Hidden Elements, select the baseboards, right click and Unhide elements in view.
Message 3 of 14
Reset Temporary Hide/Isolate.
Message 4 of 14
mwang7DKXEF
Thank you so much
After I restarted the computer, It was recovered. But I still do not understand why unhide baseboard was not working. If I meet same issues next time, I will ask you again.
Thank you so much again
Message 5 of 14
Reset Temporary Hide/Isolate next time. A lot easier.
Message 6 of 14
mwang7DKXEF
Thank you so much
But how to reset? so far it was recovered. I will ask you if I meet same issues next time
Message 7 of 14
Message 8 of 14
mwang7DKXEF
Thank you for replying.
You know how to adjust the view range for elevation?
I do not know view range can be adjusted in elevation part. I just know view range in ceiling view.
Thank you
Message 9 of 14
Far Clip Offset.
Message 10 of 14
mwang7DKXEF
thank you for replying.
What is it?
Message 11 of 14
What is it?
Weren't you asking for controlling view range for an elevation?
Message 12 of 14
mwang7DKXEF
Why need to adjust this view range for elevation? my far clip offset is 3'10'' what is this mean?
could you tell me the principle/theory?
Thank you
Message 13 of 14
Thank you
Far Clip Offset is the distance from the cut line to the limit of the view.  You won't see elements beyond the Far Clip Offset distance.
Message 14 of 14
mwang7DKXEF
Cool . Thank you sosososososo much
