Autodesk Docs does not appear in "Insert from File" dialog
pdent1
pdent1
Hi all. I'm trying to import some detail views from one project to another. Both are in the cloud using v2023. But the dialog which appears after "Insert from File" does not include Autodesk Docs (and clicking the "Drive" icon does nothing). Is this not possible and do I have to download the file from the cloud to do this?
Install/ update Autodesk Desktop Connector.
pdent1
Latest version is already installed. So you're saying it's not working properly and Autodesk Docs should show up in the dialog I referenced?
pdent1
I should add that Autodesk Docs does show up in Windows Explorer generally. It just doesn't show up in this dialog, which resembles Explorer but obviously does not match it exactly.
No issue here so I don't know what happened to yours.
pdent1
That works, thanks Toan. I was expecting to see it in the main window and not in the pull-down.
