I hide the baseboard from elevation view, later it is unable to unhide.
Thank you
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Edit: VG and Unhide Wall Sweep subcategory. If that doesn't work then check Filters.
Click Light bulb button to Reveal Hidden Elements, select the baseboards, right click and Unhide elements in view.
Thank you so much
After I restarted the computer, It was recovered. But I still do not understand why unhide baseboard was not working. If I meet same issues next time, I will ask you again.
Thank you so much again
Thank you so much
But how to reset? so far it was recovered. I will ask you if I meet same issues next time
Thank you for replying.
You know how to adjust the view range for elevation?
I do not know view range can be adjusted in elevation part. I just know view range in ceiling view.
Thank you
@mwang7DKXEF wrote:
thank you for replying.
What is it?
Weren't you asking for controlling view range for an elevation?
Why need to adjust this view range for elevation? my far clip offset is 3'10'' what is this mean?
could you tell me the principle/theory?
Thank you
Thank you
Far Clip Offset is the distance from the cut line to the limit of the view. You won't see elements beyond the Far Clip Offset distance.
