Hi all,
I am looking to set up some parameters in a family to detect whether more than 1 of 3 yes/no parameters are selected and give an output to turn another yes/no parameter on if there are more than 1 selected.
hopefully that made sense.
alternatively
I am looking for a way to have only 1 out of 4 yes/no parameters selected at a time
option 1: blank panel
option 2: addition A only
option 3: addition B only
option 4: addition C only
Gelöst! Gehe zur Lösung
Gelöst von cobyQXLPS. Gehe zur Lösung
For the alternative way, you can try this out:
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Use Integer parameter instead. 1 = opt 1, 2 = opt 2, 3 = opt 3, 4 = opt 4.
I don't know if this will help, but if you are toggling the visibility of Nested Families, you could label the Nested Families to a Family Types Parameter.
Thanks all i figured out a way that worked best for what i needed using a combination of methods,
