Unable to add custom scale
DParkRMAK
Message 1 of 10
DParkRMAK
Ok, has the procedure for adding custom scales changed in Revit2020? I don't get the dialog box when I select custom. Nothing happens at all.
Replies (9)
Message 2 of 10
Maybe it's off screen. How many monitors do you have?
Message 3 of 10
Nothing's changed.  I doesn't always pop up in the same spot though.  That's a little irritating sometimes.
Message 4 of 10
DParkRMAK
That is what I am looking for. It was not showing up at all. I wasn't even seeing the scale list when I was in the view so there was no way to call that dialog. This was on another computer, When I was able to get to it on my computer it was working fine. Not sure what the problem was.
Message 5 of 10
Can you post a screenshot of your screen with the view you are not seeing the scale list?
Message 6 of 10
DParkRMAK
It was just a graphics glitch. We have been having a lot of computer issues lately and are replacing them all.  Haven't had the issue since.
Message 7 of 10
pdent1
I'm bumping this thread because I'm having the same issue. No dialog box comes up, and as soon as I mouse away from the Properties window, the scale reverts. I installed the latest display driver, no change. If the OP sees this, what kind of "graphics glitch" was responsible? Anyone have ideas on how to solve this?
Message 8 of 10
RSomppi
I get the same thing when I try it from the properties pallet. Use the scale setter in the view controls, bottom left of view.
Message 9 of 10
pdent1
Genius! Thanks for this. I never noticed that was there.
Message 10 of 10
mpetruskavich
This was the fix for me too almost 2 years later. Properties palette drop down just reverts back to the original scale with no popup, using the scale selection at the bottom left worked as intended. Thank you!
