Unable to access the materials library
brennan
Message 1 of 8
brennan
Revit 2018 Unable to access the materials library
Replies (7)
Message 2 of 8
Did you just install 2018?
Message 3 of 8
brennan
I originally installed revit 2019 student version, because that's the version we were learning on. Then the next class  module is based on revit 2018 so I installed 2018. The materials library doesn't work in either version. When I installed 2018 a popup came up and said "a newer version of dynamo is already installed"
Message 4 of 8
Dynamo has nothing to do with materials. If you can no longer access Materials in either version now I suspect your registry got screwed up. You may need to do a clean uninstall and reinstall -- in sequential order -- of both versions. You can try a Repair first though.  Also inspect the paths being used under Option=> File Locations.  Still, I think a reinstall is best -- after a clean uninstall of both versions.
https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
Message 5 of 8
If it wasn't working for either 2018 or 2019 and reinstallation doesn't help...you may have an issue with your graphics card.
See here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
FYI...Student version is the full version with a limited time serial number...
Message 6 of 8
brennan
Yes, I looked through some forums and it looks like a video card problem. I need to downgrade the driver to nvidia version 353.62 and it looks like it worked for a few people. I'll let you know how it goes this evening.
Message 7 of 8
brennan
SOLVED:
It's now working in both versions 2019 & 2018.
It worked by using the following driver:
https://www.nvidia.com/download/driverResults.aspx/87789/en-us
Message 8 of 8
Viveka_CD
Hi @brennan
Thanks for getting back to us! Glad to hear that your issue is resolved.
