Hi there
Basic question - when you have selected a line using 'pick lines', is it possible to unpick that line (if you have picked the wrong line for example)?
Many thanks
Marty
No, not that I know of. You will just have to delete the incorrect line manually.
Ancient question but no answer... I use 'Ctrl Z' to unpick the last line selected or 'delete' key for previously picked lines (it changes the selection arrow to a selection arrow with a cross)
