Revit communicator
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
ikocev
1636 Aufrufe, 13 Antworten
Revit communicator
Hello all,
I am using BIM360 Design - free trial and I just set up the administration or I just thought that I did it right but maybe I did something wrong because when I open a project in Revit nothing happens in the revit communicator, no active projects pop up.
Additional information - I am using Revit 2018.3 version.
Can someone help please ?
Ivan
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: ikocev
Starting with 2018.3 version, Autodesk removed the communicator.  Maybe this is linked to the new BIM 360 Design setup compared to the previous TEAMS...  So no more communicator from 2018.3.
Nachricht 3 von 14
ennujozlagam
hello, need to subscribe to the Revit Cloud Worksharing service. i'm not sure if trial version will work. you can refer to this LINK. thanks
Nachricht 4 von 14
als Antwort auf: ennujozlagam
Hi, unless I'm mistaken, this link goes to a june 2018 publication and at that time, it was not 2018.3 version, but earlier.  Autodesk removed Communicator in version 2018.3 and following versions according to my sources.
Nachricht 5 von 14
ennujozlagam
als Antwort auf: Anonymous
hello mate, your sources never do their homework properly. I'm using it right now at this moment. thanks
Nachricht 6 von 14
Very interesting.  Does it work in 2019 also?  Because I have both 2018.3 and 2019, and it doesn't work on my end.  I was discussing that in another thread and they had the same source saying that it was removed...  All the better then.  How do we install it then?
Nachricht 7 von 14
ennujozlagam
hello, you need to subscribe to the Revit Cloud Worksharing service. thanks
Nachricht 8 von 14
ikocev
"As of April 9, 2018, Autodesk® Collaboration for Revit® service is now Autodesk® BIM 360™ Design "
so obviously new users can't use communicator it will be available only for members with license already.
Is there something which replace the communicator in the new platform BIM 360 Design ?
Nachricht 9 von 14
That is what I was saying.  Since 2018.3, there is nothing to replace. Autodesk just removed it...  Unless like our friend here that could use it because he already had a Could account before the switch to BIM 360 Design...  I saw some people putting it as ideas on the forums for the next versions.
Nachricht 10 von 14
ikocev
@Anonymous
I guess that '' Worksharing Monitor for Autodesk Revit 2018 " does not work too for the new members, right ?
Nachricht 11 von 14
Worksharing is still working though.
Nachricht 12 von 14
ikocev
Possible reason for not working ?
Nachricht 13 von 14
Maybe I Was not clear :leicht_lächelndes_Gesicht: , but it should work...  It is not on your end?  Are you sure you have the good one installed (the good year)?  Work sharing Monitor is not the most stable tool, but it gives a hint on what is going on...
Nachricht 14 von 14
ikocev
Yep I have it for  Revit 2018 which is exactly what I need but still it does not work.
