un-constraining lines when making a region
11 REPLIES 11
Message 1 of 12
Slamothe
520 Views, 11 Replies
I am trying to make a region with un-rectilinear lines, but Revit wants to constrain some of my my lines to horizontal.
Help?
11 REPLIES 11
Message 2 of 12
SteveKStafford
in reply to: Slamothe
You can turn off snaps temporarily, keyboard shortcut SO (stock settings).
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
Message 3 of 12
handjonathan
Hi @Slamothe
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Message 4 of 12
Slamothe
in reply to: handjonathan
It did not help.
Message 5 of 12
mhiserZFHXS
You need to be more specific about your problem then... Post some screenshots at least.
Message 6 of 12
Slamothe
in reply to: mhiserZFHXS
I am trying to draw a line between the end of the 2'-6" line and the end of the 3'-0" line to create a region. The "constraint" won't let me.
Message 7 of 12
Hold ALT when draw the boundary lines.
Message 8 of 12
Slamothe
in reply to: ToanDN
Thanks.
Message 9 of 12
SteveKStafford
in reply to: ToanDN
Hmm, ALT while sketching doesn't do anything for me. Must be missing something.
Snaps Off (SO) followed by Snap Endpoint (SE) works for me... I left off the second step in my earlier reply, sorry.
Message 10 of 12
Slamothe
in reply to: SteveKStafford
Turns out ALT doesn't work when the line reaches a certain length, but SO & SE does work.
Thanks.
Message 11 of 12
Lachlan-JWP
You can also press TAB while hovering the cursor near the endpoint your want to snap to for Revit to cycle through the different snap options.
Message 12 of 12
Ordinarily yes, but at the distance described in the image the snap fails to "see" the endpoint. Quirky...
Forma Design Contest
Technology Administrators
