True White Grade for Perspective 3D Views
3 REPLIES 3
juliemasko
400 Views, 3 Replies
juliemasko
Hello, for my design packages I use exterior 3D Views: Perspective (I don't render them though). I was using Revit LT 2019 and had my grade appear as true white. (See attachment).
I've finally upgraded my system to Revit LT 2023 and am updating all my materials and template. I can't for the life of me figure out how to get my grade appearing as true white. Its either yellow (as is the rest of my building then) or various shades of grey. (see the attachment - ignore the random building materials).
I've also attached the Graphic Display Options and the grade material from the Revit Library. Let me know if you need anything else. Thanks!
Labels (6)
3 REPLIES 3
in reply to: juliemasko
Big change in 2021.
Help | Enhanced Realistic Views | Autodesk
Big change in 2021.
syman2000
syman2000
Have you tried to change the realistic color correction in the LT2023?
juliemasko
juliemasko
Yes I have @syman2000, see the attachment below for current settings for this view.
