Hello People could do with your help, i've used revit for a year now producing plans, elevations, sections and details. I have now been asked to produce setting out drawings in revit from autocad files. I have been practising and watched a number of youtube videos but still having issues.....
* Can i change the revit survey point to have an extra number after the decimal point, so it matches the autocad coordinate? (as currently my coordinate points slightly off from the ones DWG reports, concerning)
* Is the best practice to first set the survey point to a coordinate from the DWG pin it and then unpin the dwg and move the dwg to concede with the survey point and then pin the dwg?
*If i have multiple houses on a site but only one base point how do i bring in the subsequent houses if there is only one base point?
*If i only have one building type, is it good practice to just have one file which contains site plans , elevations etc and only use linked file if i have separate house types?
thing thats it for now, thank for the support people and happy xmas
