Troubles in copy/monitor with rectangular wall openings
Message 1 of 1
We use copy/monitor for the first time in the office, and it works fine except the openings.
The architectural model is linked to my construction model. Architects use stacked walls with doors and windows in the facade.
Wall with rectangular straight wall openings are copied and monitored from the architectural model to my construction model and the openings were accurate when they were copied.
Meanwhile the architect has made changes in the position and size of the windows. When I run the coordination review, the changes are reported, I even can choose " Modify opening in..." as an action. I apply it, Revit does not give any error message, but it neither changes the position/ size of the opening.
Next time when I run the coordination review all the openings get listed again, those I applied the "Modify opening .... " action before.
Is there anyone who also experiences problems with Copy/monitor? Is it a bug or am I missing something?
Replies (0)
