Different far clip offset in same section
XXalessio.amodioXX
XXalessio.amodioXX
Hi all,
I have to prepare a section view for a sloped structure.
I want to have different far clip offset. In middle part i want to see as far as i can for architectural purposes.
Roof part and foundation one just the first line of beam/pocket to not have a messy view.
To make myself clearer I have attached a pic.
Does someone can help me out?
Karol_Piroska
I'd say the only way is to create two sections with two different far clipping offsets. The section with foundation/roof you can "divide" using horizontal view break to remove the middle part of the section. Then place these two sections on top of each other on your sheet.
XXalessio.amodioXX
Hi Thanks for the answer,
it might work a solution but seems a bit tricky. Furthermore how would you align the two created  section, with different far clip offset to each other?
Avaris.
@XXalessio.amodioXX You could do that using a reference plane that is visible on both sections. On sheet, there is a possibility to snap to grids, levels and reference planes.
Karol_Piroska
I think it is simple enough
https://autode.sk/2WiSgLF
When you place them on sheet you will see the fainted blue guide lines when they align.  It is fairly easy.
gopinathan_kadavil
Community Visitor
Community Visitor
Not able to see the page. Could you please advise?
