Random hole in wall appears when joining 2 walls
4 ANTWORTEN 4
Nachricht 1 von 5
laurenslembrechts
1381 Aufrufe, 4 Antworten
Can anybody tell me how I fix this issue where I get a random hole in my wall?
I can not get the walls to join without this hole appearing. It's not the floor or the perpendicular wall either I tried removing those.
Tags (1)
4 ANTWORTEN 4
Nachricht 2 von 5
Okay I solved it but it is a load of bs why this has to be so difficult.
Does anybody know a why and+or a different solution?
Nachricht 3 von 5
nmarcelis
als Antwort auf: laurenslembrechts
Problems with wall joins often occur because of the layer propreties of a wall.
You can find more information about this topic here.
If this helped you please accept this as a solution.
Revit Certified Professional Architecture, Structure and MEP.
Nachricht 4 von 5
Just join those walls back together and then switch join order.
it occur very often when you have 3 elements joined together (wall + wall + slab)
Nachricht 5 von 5
Sometimes it's just a "B".  Split Wall is my go-to tool in situations like this.
