Message 1 of 9
Trouble importing a modified AutoCAD 3d solid (.dwg) into Revit
09:37 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I downloaded a .dwg to be used as a BIM object from a website of nationally know brand of appliances.
I then modified the AutoCAD 3d solid (.dwg) in 3ds Max by applying materials and now I am having a problem importing the .dwg and or the .dxf into Revit.
I have cycled through using all 5 options in the Positioning Dialogue Box when I go to importing the CAD file:
- Auto - Center to Center
- Auto - Origin to Origin
- Manual - Origin
- Manual - Base Point
- Manual - Center
NOTE: I have already imported the pre-modified version of the same .dwg file into Revit so, I know the issue is because of something that occurred due to the modification on the original .dwg
I am currently looking to verify that the .dwg and or the .dxf did not import on a different level or plan in my project.
Thank you,
Mike
