trouble exporting sheets as dwg
jnoordzij
Message 1 of 24
jnoordzij
Hi
Im having trouble exporting sheets as dwg. In the exported dwg file, the layout views appear empty. In model space the content is scattered around randomly. Please see the screenshots. What am i doing wrong? How can i get a good export of the sheet lay out?
T.I.A.
JN
Replies (23)
Message 2 of 24
amorap
Hello from Spain
How did you have done the set up for exporting to DWG?
Check the units exporting from revit and importing in AutoCAD, it could be an issue with view extens in AutoCAD.
Are you exporting the revit views as external references?, if so, try to repeat the export but disabling the exteranl reference option.
Regards.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Message 3 of 24
jnoordzij
Thanks for your reply!
Yes, i am aware of the checkmark 'export as external reference'. Bu that's not it. See shots:
shot 3: my sheet in revit
shot 4: my general export settingsshot3.JPGshot4.JPGshot5.JPG
shot 5: the result
Any other ideas?
TIA
Message 4 of 24
jnoordzij
...and here a view of the exporting Revit units. How do i check autocads importing units?
Message 5 of 24
jnoordzij
i also tried setting Coordinate system basis to 'Shared'.. but no effect.
Message 6 of 24
aleksei.tkachenko
Hello
Try to load export layers for text file that I have attached. Maybe it will help. You can also send dwg file here so that other can check if your AutoCAD works well or not.
Message 7 of 24
jnoordzij
Thanks for your reply. I tried your text file but no result.
I have attached the dwg file. Can you see if somethings wrong?
Message 8 of 24
jnoordzij
I have found some similar issue. Maybe it has something to do with it, maybe not ???
When i have a view on a Revit sheet, and when i rotate that view by 'Rotation on sheet' to 90 degrees for example. Then the view jumps away a long distance somehow... Seems like the rotation point is awkwardly off centre.
Somehow this 'jumping away' seems similar to the model space of the exported dwg file... Could this be related or do you think not?
Message 9 of 24
aleksei.tkachenko
DWG seems to be OK, units are set to mm and so on. The next step is to attach rvt-file to check export result from other PC and Revit.
Message 10 of 24
jnoordzij
I cant attach it. Its too big (1GB).
Should i send it to you via WeTransfer?
Message 11 of 24
aleksei.tkachenko
Sure, you can do it.
My e-mail is [email protected]
Message 12 of 24
jnoordzij
Thanks. I am sending it to you now.
Message 13 of 24
rimacoca
Close all programs in your pc (autocad and revit)
Install a tool like ccleaner and clean your temp FILES
OR
You can do going to your pc and type %TEMP% and delete all files
Open the Revit file.
Select all the view from the sheet  and activate Crop View and Annotation Crop.
Export the sheet but change  the file name and save in small path like C:\newfolder\
A KUDO is always welcomed; However, when the above answer helps and/or clarifies your query; kindly mark this reply.
Submitted ideas
/ All Revit up dates
Projects BIM Integrated Services
Message 14 of 24
aleksei.tkachenko
@rimacoca I have the same export result with @jnoordzij file on my computer. I suspect that troubles can be caused by size of the file. Can not figure out why it is almost 1GB. I think this is the case that Autodesk Support could take a look at.
Message 15 of 24
jnoordzij
Allright, so how do i get in touch with autodesk support? Are they active on this forum? Or should i give them a call or something?
Message 16 of 24
rimacoca
Can you send me the file? Can i try?
ricardo.carvalho at pbimis.com
Submitted ideas
Message 17 of 24
jnoordzij
Sure. Sending it now. Please give me your thoughts.
Message 18 of 24
i figured at  1Gb they were modelling the planet....... 😉
Message 19 of 24
jnoordzij
Yeah, maybe afterwards we can also find out why the file is so big 😛
Message 20 of 24
jnoordzij
@rimacoca, did you find out anything?
