I've been having some trouble with my topography. When I place more than just the exterior points, I create a building pad or when I use the sub region tool it creates all these black lines from the corners of my topography to the building pad/sub region or to the other points. The topography itself is fine slope wise, it's just got heaps of black lines all over the place, and they're not the contour lines. Is there any way I can fix this and get rid of these lines??
Gelöst! Gehe zur Lösung
Gelöst von amorap. Gehe zur Lösung
Hello from Spain
In VG open or expand topography cathegory.
Be sure to untick trangulation edges
If ticked, then all the triangulation will be visible.
See the image above (my revit is in spanish)
regards.
