Trouble Controlling Wall Fill
12 REPLIES 12
Message 1 of 13
PhilvK
616 Views, 12 Replies
I want to control the wall fill on some walls. The Generic walls at the orange arrows below are are assigned the Default Wall material which doesn't have anything assigned to that category for cut patterns. The View Specific Elements Graphics for these walls are set to By Material.  The walls are still showing as filled gray in Hidden Line mode. What else could be controlling this please?
12 REPLIES 12
Message 2 of 13
mhiserZFHXS
in reply to: PhilvK
Phasing and phase filters.
Message 3 of 13
PhilvK
in reply to: mhiserZFHXS
The walls are set to New Construction phase. If they're being controlled by Phase Falters, shouldn't they be solid black based on the settings below?
Message 4 of 13
in reply to: PhilvK
Sounds like conflicting overrides.
It may not always be clear which method of override takes priority over another method, that is, which method "wins" in determining the display of the element. The following list may not cover every scenario, but it includes some common overrides. (1 is the highest priority and 10 is the lowest priority.)
1. Linework Tool
2. Override Graphics in View By Element Halftone
3. Graphic Display Options - Silhouette Edges
4. Override Graphics in View By Element
5. View Filters
6. View Depth - Beyond Line Style
7. Phasing Graphic Overrides
8. Visibility/Graphic Overrides Override Host Layers Cut Line Styles
9. Visibility/Graphic Overrides Projection/Cut Lines
10. Project Object Styles
Help | Element Visibility Override Hierarchy | Autodesk
Message 5 of 13
mhiserZFHXS
in reply to: PhilvK
Ah, then its your V/G overrides / view template.
Phase overrides are also determined by the phase filter, so you must have a filter applied that doesn't override new materials.
Message 6 of 13
in reply to: PhilvK
Wall are New Construction but what is the what is the View's Phase Filter set to.  Also, what is the Detail Level of that View? Just contemplating the possibility of a Coarse View Fill/Pattern (under Wall Type Properties).
Message 7 of 13
PhilvK
in reply to: barthbradley
VG settings are blank. Phase Filter set to Show All which says 'By Category' for 'New'.
Thank you guys for your help...I'll keep looking.
Message 8 of 13
in reply to: PhilvK
Set the View's Phase Filter to Show Complete.
Message 9 of 13
PhilvK
No change under View Complete, or even Show New.
Message 10 of 13
mhiserZFHXS
in reply to: PhilvK
None of your filters have "New" set to "Overridden". So its not changing any of them.
Message 11 of 13
@PhilvK
Coarse View?  Like I said above, a Wall Type can have a Coarse Scale Fill Pattern/Color.
Message 12 of 13
mhiserZFHXS
@barthbradley
We'll figure it out one of these days 😂
Message 13 of 13
PhilvK
These walls display as expected in Coarse View
State of Sustainability Webinar
