Transparent walls in my model
Message 1 of 25
In 3D view the walls look semi transparent for some reason, which in turn seems almost wireframe. Transparency is set to 0, there's no filters, I've checked phases and I'm looking at it in shaded / realistic. Not sure how to get my opaque walls back and I can't undo
Any help would be much appreciated
Replies (24)
Message 2 of 25
Sahay_R
Have you checked your VG?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 25
PijPiwo
The view could be corrupted. Delete it and create a new one.
Message 4 of 25
Nope, the transparency is 0
Message 5 of 25
Sahay_R
Just as a test - try swapping out these walls with the different type.
Rina Sahay
Message 6 of 25
Don't waste your time trying to fix it. Just delete the View and create a new one from the 3D view button.
Message 7 of 25
semko_dm
HI!
Did you try to open this file on another machine? It can be hardware problem.
Take a look at this article.
Also you can provide us a piece of the model, it would be a lot more easier than keep making guesses.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Message 8 of 25
loboarch
From the looks of the image, this is going to be the fastest and easiest (and probably only) solution. Default 3d views sometimes do this. Just delete and create a new one. It is a default view anyhow so no real loss.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 9 of 25
Is there a CADD file inserted in your project?
If so go to 3D view and hide the CADD file. Your walls will go solid.
Message 10 of 25
I have this same problem and I've tried all suggestions I could find online. I've deleted the view and made a new one, I've checked phases and their overrides, I tried changing walls materials (the ones that were "air" even though they weren't the exterior material), I´ve checked VG options, display options, turning off dwgs..
This is only happening on the default 3D view. Not a must but really annoying. Any suggestions on more things to try?
Message 11 of 25
Sahay_R
Try to right click on the wall. Override graphics in view. Make sure that the object's transparency is set to 0.
Rina Sahay
Message 12 of 25
Message 13 of 25
lee_cutts
Has the wall material (e.g. concrete - C35) been set with a transparency under the material 'Graphics' tab?
Message 14 of 25
Sometimes it could a graphics card problem, however, try to check material transparency or create the wall and the view again in new project.
Message 15 of 25
I was having a similar issues with the walls showing transparent in the elevations, even though they weren't  set to transparent, wireframe, or with any overrides. This transparent wall display was randomly happening in some views and not others. As recommend in this forum, after I hid the CAD plan that was referenced in, perpendicular to the view, the walls revert to the normal display settings.
Message 16 of 25
bordonhn
Community Visitor
Community Visitor
agree. it seems to happen very often when the model is too heavy.
Message 17 of 25
This answer should be marked as the truly correct one.
This is a condition/bug of Revit when you have imported CAD inside your view. I have tried uncoountable ways to solve it by changing parameters, but only hiding solve the transparent walls issue.
Message 18 of 25
mauricio_mssf
Hi @Anonymous
Deleting and recreating the 3d view will resolve
But if you don't want to lose your eyesight, check your view properties, the "Eye Elevation" and "Target elevation", if the numbers are large, change them and then rotate.
Or click on the viewing cube and then rotate
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 19 of 25
jmh.archdesign
Yes, thanks @Anonymous
In the affected view(s) hit VV --> Imported Categories tab --> uncheck any CAD imports
Message 20 of 25
19184443
Observer
Observer
I couldn't fix my transparent walls with the solutions offered so I created a new wall from scratch. Then I selected all instances of the problematic wall type in the project and changed to the new wall. I really hope this helps someone struggling with the same issue.
