Transfer One Material to another Revit Project?
Is it possible to transfer individual materials from one Revit Project to Another, instead of the entire material library?
Sahay_R
Create an object with the material applied.
CtrlC and CtrlV into another project.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Thank you! Very simple solution...very quick reply.
Thank you very much for your contribution. We have been dealing with this issue for a day, can't believe it was this simple.
This works unless a material by that name already exists in the destination project.  Then you will have to change the name of one of the materials.
dc
this worked, to point. The choice appeared in the materials selection, but the colour wasn't adopted. The asset isn't shared, which is supposedly good (the little hand shows "0") but the asset is locked.
