Is it possible to combine the 'smart' spot slopes with a dynamic customizable arrow that I have created as a line based detail family? Or would the better way be to customize the leader parameters for the Spot Slopes?
Gelöst! Gehe zur Lösung
I think it would the better if you customize the leader parameters for the Spot Slopes, Since it has the parameters to modify.
Thank you. That worked!
@Radish_G - @ToanDN is absolutely right. The accepted solution by @Anonymous pointed at modifying parameters. Please experiment with different parameter values to get the effect that you want.
Hi, I have added a short screen cast related to this, will be happy if you check it out.
Thanks.
